IcePickFreak
- Jul 12, 2007
- 2,428
- 9
- 81
Ah ha. The landlord solution. :thumbsup:F that...I will have my landlord do it. That way, he can have his head bit by a rabid animal.
Are you a chick? Just go up there and do something about it...no need to wait on a landlord, just do it.Every now and then, I hear this scraping sound above me. I sounds like there is something dragging a dead animal around. Then, at times, you hear this scraping....like it is trying to dig something up. Sometimes, I take the broom and just bang where the sound is. At the point, you hear it scrambling away only to come back 30 seconds later. What do you think it could be? Mouse? Squirrel? Racoons?
Birds, squirrels, chipmunks, neckbeards...
Better than here.If so, I pity the OP. Attic would be FULL of fecal matter in no time at all.
It's a good thing you have a landlord because you do not have the requisite sense to own your own home. (If you hear an animal in your attic you fvckin check it out, even if it is a hassle due to blocking the access!)
Yes, because damaging the apt to get to attic, when you can tell he specifically boarded up the access path and even sealed it all over to prevent access, is clearly the right thing to do.
