I've been playing around with some overclocks on my P35+E6420 setup. Keeping the volts low, I can get 350x8 or 400x7, both good for 2.8GHz. With 400x7, I run the RAM at 800MHz and tighten the timings. With 350x8, I run the RAM at 840MHz and run stock timing (5-5-5-15). The difference between the two is not noticeable, but which one is theoretically better? I'm upgrading to an E8500 in the next few days anyway, but am just curious about my options.
TIA!
Also, if this has been asked before, sorry! I had trouble finding good results with the search function.
TIA!
