If I had the time, had a place to bring it, and wanted to pay the money, I would have the engine hot tanked and get it over with but alas, I live in Upstate NY. What's the best method to remove crap from the metal on the block and tranny such as build-up of sediments, deposits, and rust spots on other parts of it.
I was thinking about just getting a fine wire wheel brush from the Depot but I wanted to know if there was an easier method to use or what else I should use to aid in the removal (engine degreaser to help break it up?...no idea) and return it to all it's glory. I'll also be cleaning other parts like the alternator, intake manifold, throttle body etc etc (exterior only, I can handle carb cleaner).
Thanks in advanced.
Thanks in advanced.
