- Dec 7, 2006
- 50
- 0
- 0
Processor: E6400 Conroe
Graphics card: GeForce 7600 GT 256MB
Ram: 2 x 1 GB DDR2 something set up for dual channel
I'm a novice at building PC's... never OC-ed but plan to because of how well the processor lends itself to it. I have everything but motherboard/ram figured out. I do mostly gaming (not hard core) and print graphics.
What I'm looking for is a MB/ram combination:
Priority #1) STABILITY
Priority #2) EASE OF INSTALL - I don't want to have to do some trick with installing different ram, then my final ram. I don't want to run into some complication with the optical or hard drive when I try to install the OS.
Priority #3) EASE OF OVERCLOCKING - Being a first time OC-er, I shouldn't get too complicated of a motherboard to start with. I'd take ease of use over a slight power potential increase.
Motherboard requirements:
XTA
G965
Dual Channel Support
SATA II
Raid 1
S/PDIF optical out
$100 - 200 target budget (preferably closer to the first half of the range)
Some motherboards/ram I've considered
Gigabyte DS3
ASUS P5B -E or Deluxe
Abit AB9 basic or pro
Intel BOXDG965WHMKR
DDR 800 or DDR 667 Patriot or Super Talent ram
What do you feel the most hassle free (not the most powerful) combo would be? It doesn't have to be one of the ones mentioned above. Is there truely enough benefit to make DDR 800 another $50 - 80 worth it? If you don't overclock, I don't think so. But what if your a beginer like me?
Thanks All!
Some of the wonderful resources I've used so far are:
Motherboards, Ram, Micron Ram, Article, Article, Definitions
XTA
G965
SATA II
Raid 1
S/PDIF optical out
Gigabyte DS3
Intel BOXDG965WHMKR
Thanks All!
