what's a step motor
cheapgoose
so I went to a electronics sale today and walked by some step motors,
so what is a step motor? ask.com wasn't any help.
Originally posted by: Shockwave
Originally posted by: Tetsuo <a class=ftalternatingbarlinklarge href="[L=http://www.google.com/search?q=what%20is%20a%20step%20motor" target=blank search?q='what%20is%20a%20step%20motor"[/L]' www.google.com ]http:>What is a step motor</A>
WHOA! How did you find that?!?!
OMG I DON'T KNOW
A step (stepper) motor is a motor that has several windings that allow you to rotate the shaft in very small increments and precisely position the rotation of the shaft.
come on guys, already try that, all I found were companies that sells them and a lot of stuff I don't understand.
anyone wanna translate that into none tech language that I can undestand?
edit: thanks boink.
Originally posted by: thedarkwolf
They also have a lot of torque and when you stop one its really hard to manualy make it move.
Used lots in robotics and positioning, because you have precise control over positining of (usually) a pulley on the shaft.
thanks guy. I think I have an idea now.
so you need an controller than right? can't just hook it up to power like reg. motors?
you need a controller. it's not plugin and run like regular motors. the coils need to be energized in a certain order for it to go the way you wanna
there are usually four wires coming out of it. you need a controller to pulse those wires in the correct sequence to step it forward or backwards. depending on the motor, they can step in small degree increments (1.5, 3, so on). i'm working with one right now for my senior project 🙂
some pics for you from my summer lab class... http://pics.bbzzdd.com/users/meanmeosh/stepper-motor.jpg
http://pics.bbzzdd.com/users/meanmeosh/controller.jpg
the controller is making the stepper motor turn forward or backwards, making the elevator attached to it go up or down.
What's with the Teflon tape?
