What's a practical way to test an LCD monitor in the store?
bgc99
472
My options for seeing an LCD in person are limited to a BestBuy and an Office Depot. What would be a good way to test out response time?
One thing I did was to drag a window that contained text around the screen. Is checking how blurry the text gets while the window moves a decent test? I noticed on one the text got very blurry even with the window being moved very slowly, while on another it seemed pretty clear while moving the window quite a bit faster.
I'd like to be able to see a monitor in use before I buy but most of them are just hooked to a display slideshow and not a computer you can get your hands on.
BGC
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
I haven't done this, but something else to check out might be to open paint and make a really big black rectangle and see how the mouse fades when you go over it quickly...
imverygifted
1,368
most stores u can return even w/ out a reason(they ask but its not necessary) in the first week or so.
RelaxTheMind
2,245
do what i do
i open a command window full screen with alt+enter and type "cd \" then "dir /w/s" boom you have a good idea of the ghosting.
try it on your current computer and you will see what im talking about
bgc99
472
Originally posted by: RelaxTheMind
do what i do
That goes by so fast it's blurry on my CRT. LOL
BGC
