- Feb 8, 2004
- 12,604
- 15
- 81
Can someone link me to one for the 2.4 patch, i want to kill other people easily and i dont want to mess up the talent tree thing.
Originally posted by: AyashiKaibutsu
bind your instant cast dots + fear to every key on your keyboard and roll your face across it.
Warlocks are strong, but rogues are the strongest PvP class.
I haven't played my 'lock in many months, so the advent of shadowstep is something I never had to deal with... but since it was put in, they may simply not be killable for warlocks. Or anyone else, but I digress.
Gotcha, ive been doing fear with that curse of agony spell and corruption, but what do i do with stat points? Im level 16 and havent used any yet in case i mess up.
Originally posted by: Soviet
Ok im beginning to get the idea this isnt like diablo II where one class is clearly better than some other classes.
I cant kill people with my lock, im level 18, and ive fought about 5 1v1 duels and lost them all. People run up to me and hit me and i die... i cant stop this because they ignore my pet and once they get feared they run out of range of my spells and when they come back i cant keep walking backwards because i need to stay still to cast the shadow bolt to hurt them and i die...
Help me! What am i doing wrong? What should i be doing to remedy this?
And you'll keep losing unless you level up. You don't have stamina to survive an initial burst from other classes, and you don't have any skills or talents to protect yourself.Originally posted by: Soviet
Apart from not leveling up, there's one thing: walking backwards. Run either sideways or forward, so you'll be going at the same speed as the other guy, and they can't catch you unless they use some kind of speedup or teleport effect. If they can't catch you, you win because your damage over time spells kill them. Avoid the other player like they have rabies and you are on the right track.People run up to me and hit me and i die... i cant stop this because they ignore my pet and once they get feared they run out of range of my spells and when they come back i cant keep walking backwards because i need to stay still to cast the shadow bolt to hurt them and i die...
Resto druid? Debatably the most powerful class in WoW. I neglected to mention it becuase of the spec's reliance on other players in PvP. 99% of WoW players are moderately-severely retarded, and finding a quality player is damn near impossible. And if even if you do, what's the point You sit there lifeblooming the guy who's actually having fun... no thanks.Originally posted by: BenSkywalker
Not that simple at all. Unless they are packing dual glaives, rogues are a minor nuisance for my druid.
But I digress. Yes, a resto druid is a good match for a rogue.
Warlocks are strong, but rogues are the strongest PvP class. Anyway, spec 23/38/0, eg. SL/SL (Siphon Life / Soul Link). MO is to cast siphon life, curse of agony and corruption on people, then drain life till they die. Of course some classes take a bit of footwork, especially rogues. I haven't played my 'lock in many months, so the advent of shadowstep is something I never had to deal with... but since it was put in, they may simply not be killable for warlocks. Or anyone else, but I digress.
SL/SL locks are weak to rogues, deep demo however, is not. Using the FelGuard to counter the rogues stuns +fear +nub coil= easy mode, at least, that's how my 2s partner makes it look. That said, MS warriors he deals with much easier SL/SL then when he's deep demo(Felguard doesn't hit plate hard enough to matter much).
Shadowstep is annoyinig, Cheat Death is much worse IMO. I have been offed several times on my mage by a rogue that I had down to 10% health or less when I was still at 90%. Cheat death effecitvely makes rogues have roughly 30-40K hp if they get lucky with it :| Cheat Death is getting nurfed in the upcoming patch. For the druid no biggie, he can't kill anything remotely quickly, just keep my dots and hots up and eventually he will die![]()
You can respec if you don't like how something works. I normally budget about 400G a week for respecs for my toons(mage goes dps frost for BGs, pvp frost for arenas and deep fire for raids, druid is back and forth between tree for raids and bear for when someone needs a tank). To start with, your respec only costs 1G, it never goes higher then 50G(that probably sounds like a lot now, but it is nothing at 70).
I would reccomend you go demo down to felguard to level- making it to 70 demonology is by far the easiest way.
Originally posted by: Anubis
use this armory as a guide
http://www.wowarmory.com/chara...r=Ner%27zhul&n=Azzurri
Resi to 494 -> Spell Dmg -> Haste -> Stamina is my priority, but it also depends on your team setup.
Your playstyle really depends on your team setup: sometimes you're going to want to put a ton of pressure on the team by CoA/Corruption/SLing everything, sometimes you'll want to control a caster with CoT, other times you'll want to just watch your DRs and maximize your CC time with Fear, and even other times you'll want to focus on Mana drains. I'd make sure you have your 3 main DoTs, Drain Life, Drain Mana, Fear, and Death Coil bound to something accessible.
For mods, Proximo is paramount of course. Any sort of mod that gives you timers and DRs is great, NECB still has DR counts on it even though its outdated. There's others such as Afflicted I believe as well.
rogues who PVE dont have cheat death
I never have much of an issue with demonology locks using felguards. Sure they can intercept me, but unless they time it near the end of my stun (so in other words, the felguard's intercept stun lets my stun fade without letting me apply a new one), they won't have a chance. Also, most locks are too stupid to keep their felguard at a distance so they can intercept. In a 1v1 case, they're screwed unless there's some random target nearby. In arena, they can simply throw it at another opponent and then intercept the rogue.
I am the biggest Jew you'll ever met when it comes to respeccing.
I really, really hate druids on my rogue. The fact that a resto druid can literally just spam noobfire for 1k damage a time and I can't do crap because of rejuv and lifebloom. Of course, I'm used to fighting completely PVP epic'd out druids and my character certainly is not epic'd out (as mentioned above, pvp blues FTL). The lowest I could get a resto druid was about 50% before he was able to get away. I think I kinda messed up though, so that may be why.
Affliction is easier to level as since it's more mana efficient as you're not always in casting.
Try rolling a mage and go against a tree. It isn't possible unless the tree is absolutely horrific.
What's it take, 15 minutes to make enough money to respec at the cap? Based on what you say, it will take you a lot less then that. To each his own, but to be effective in a variety of rolls, almost all classes need to respec.
You won't beat a well played resto druid that outgears you, not a chance.
Asked my bud about that, he said aff until you hit 50, then demo to 70, then dest to raid.
