What's a good, QUIET AMD XP cooling fan?
bluemax
7,182
Like the title says, I'm looking for a good fan that's QUIET!!
I'll be cooling either an XP2200+ TB or an el-cheapo 1500+ Palomino.
Your recommendations?
Adul
44
danny.tangtam.com
vantex airoflow is fairly silent. I am sure zlaman has even quiter solutions.
personally I would use a thermalright sk800u with a quite 80mm fan
Boonesmi
14,448
i really like the thermalright heatsinks (the slk900 is killer) and then use a low rpm fan
my personal setup is a slk800 with a panaflo L1a (almost totally silent)
allupinya
I use the Thermaltake Volcano 11 on auto fan speed it is quiet baut can kick itself up under load never goes above 4280 rpm playing dx9 games best i`ve owned...Highest temp recorded under heavy load is 136*f 2800+ running @ 3467 Mhz
Boonesmi
14,448
Originally posted by: PorBleemo
Panaflo L1A are good fans.
dang skippy :)
i replaced all my case fans with panaflo L1A 80mm fans (6 fans including the one on my slk800 heatsink)
the end product is very quiet and runs nice and cool :D
