Whats a good in game hardware monitor (display FPS, GPU temp, fan speed)
AnMig
Currently using fraps to display my FPS during games.
I saw a few youtube videos where they have GPU temp, fan speed displayed while playing and was wondering what software they where using.
Currently have a I-5 2500k @4.5ghz
Gigabyte HD 7970 x2 @1050mhz crossfire
Catleap 1440 resolution
Trying to see what my GPU temps are while playing and see if I can live with lower fan speed to avoid noise.
Thanks
The MSI On-Screen Display Server application should have been packaged with your Afterburner install. By default it simply shows FPS when you turn it on, however you can download HWiNFO and when you run it go to the "configure" menu and it will hook into the OSD program allowing you to set what items you want to view (it should give an checkbox to display in RivaTuner iirc).
I really like the remote server you can run alongside afterburner. I can check my temps, etc from my phone or tablet while gaming, without it having to interrupt the game screen.
