What's a good HS/F for the 1.4 gig TB Cpu? and Case Fan?
Shummy007
9
Can someone tell me what's a good Heatsink and Fan for the Athlon 1.4 gig Thunderbird CPU? And what a good 80mm Case Fan to buy (want low noise and maximum cooling)?
Also need to know a good vendor to buy them :)
Willing to spend no more than ~$40 for the HS/F and no more than $8 for each Case Fan.
Thanks in advance for the info
teckmaster
1,256
I just built a 1.4GHz Thunderbird and used a CoolerMaster HSF and it is not in any need of a case fan. It keeps it plenty cool
Heres the Model Number: CoolerMaster DP5-6I31C AMD Approved
nicowju
3,880
I was happy with the Thermoengine with teh delta fan, and now I'm happy with the Thermalright SK6 with the delta fan
heffe734
2,304
Don't get a coolermaster...yes it will do the job but in my opinion it's a POS HSF. Invest in something like the sk-6, gladiator, alpha pal...all are under 40-45 bucks and some even 20 bucks.
SpeedTrap
Banned
Apr 2, 2001
1,705
zalman 5000 with a 60 to 80mm converter and the sunon 50cfm fan 89F mos tof the day but then again the heat wave has seemed to pass
