What's a decent 15" LCD monitor for 150 bucks or less?
I got a NEC/Mitsubishi 15" LCD for $150 if you want 😉
Built in speakers and 3 or 4 port USB hub in perfect condition.
Might still have warranty left from staples since I purchased an extended warranty.
I've occasionally seen 17" LCDs close to the at price, but any 15" monitor should be okay. You will get a little ghosting, most likely, because it isn't going to be DVI at that price, but XGA resolution isn't taxing on a VGA connection, so you'll be perfectly alright.
I have a 15" LCD, but I wouldn't buy one now, I would either 1. save/shop for an affordable 17", or 2. stick with the CRT until I could do 1.
