whatis the best ultra SCSI 320 controller out there right now?
Jincuteguy
380
im planning to get an Ultra SCSI 320 hard drive, but in order to use SCSI hard drive, I have to buy an Ultra SCSI 320 controller right? if so, what is the best controller right now ?
dexvx
3,899
Any PCI-X U320 controller by LSI Logic or Adaptec is good. If you want to use the RAID, go LSI Logic.
BuckNaked
You can use a 160 controller if you want.... won't be any kind of performance hit unless you are using multiple drives....
Lynx516
272
How long is a peice of string. Adaptec make good ones but you could end up spending thousands on a controller.
jose
2,079
check out the Adaptec 29320-R, it's a 64bit card that's backward compatible.
Regards,
Jose
Jincuteguy
380
I will only use scsi hard drive for my personal computer, im not trying to get a controller for a server or anything that is big. So what is the best controller ultra 320 out there that has low cost and stil have good performance?
dexvx
3,899
If you're getting it for a personal computer, than chances are it will be for a regular PCI slot (32bit/33Mhz). In that case, there would be no advantage from getting a U160 controller instead. Adaptec and LSI Logic U160 controllers can be had on eBay (new) for around $50. The cheapest U320 controller is over $100, and it comes in PCI-X form factor, which is backwards compatible with regular PCI.
helpme
3,090
Lsi makes great cards themselfs, cheap too. The other companies using their Chipsets also make similar cards.
Jincuteguy
380
So isn't Ultra 320 controler faster than 160? But you said 320 uses PCI-X slot whihc I dont think my motherboard has one cause its not an old system. So only 160 has PCI slot?
selene
282
scsi and low cost doesn't belong in a sentence..
I believe u160/u320 is total bandwidth available to each channel, meaning if you put 4 drive into a u160, u can pretty much divide 160/4. Only if every drive is being access at the same time.
So having 1 u320 drive on a u320 controller wont be much better than having 1 drive on a u160 bus. You'll never max out u320 bus speed
selene
282
3 channel are usually 3 port on a controller.. I have a few adaptec 4 channel scsi controller, u160 per channel. Each channel supports 14/15 drive (how ever you calculate it) - 14*3 drive supported on the controller.
Best would be putting 1 drive on each controller, giving you a u160 bandwidth on every drive.
dexvx
3,899
PCI bus is limited to 125MB/sec. U160 is 160MB/sec. U320 is 320MB/sec. You're not going to even get U160's max bandwidth. If you have a PCI-X slot, than its a different story, but since this is for a desktop, I have my doubts.
Jincuteguy
380
So most modern motherboard doesn't have PCI-X slot right? so why th en ew ultra 320 controller doesn't support the new PCI slot in modern system? So I know tha tI don thave a PCI-X slot on my motherboard, so I can't get ultra 320 controller ????
dexvx
3,899
No, PCI-X is used for server/high end workstations. A PCI-X U320 SCSI controller is backwards compatible with normal PCI.
Jincuteguy
380
I have an Asus P4T533-C motherboard, and im not sure if it has PCI or PCI-X slot, PCI right? anyone confirm??? CAue I never seen an PCI-X slot before :) Also , it's ok if I buy an Ultra 320 controller and use it on PCI slot (not pci - x)?
JC
5,854
73
Just use an Adaptec 29160. It's compatible with your 32-bit PCI slots. You're not going to saturate the PCI bus anyway, so no real need for a U320 controller.
JC
randumb
2,324
Since you only have PCI slots, get a Ultra160 (160mbps) controller. An Ultra320 (320mbps) controller would be a waste of money, since PCI slots only go up to 133mbps.
Zepper
18,998
There is NO drive that has a transfer rate higher than about 78MB/sec. A U2W (U80) host adapter (don't say controller around SCSI) would allow one to run one of those drives at full clip, a U160 HA - two drives etc. You figure it out... As others have pointed out (are you reading your replies, habla English?), the normal PCI bus runs out of steam before a U160 adapter would. So on a normal mobo anything more is a waste of money. If you only plan to run one HD, even U160 HA may be a waste of money if you can find a U2W cheaper.
.bh.
:moon:
Jincuteguy
380
besides, im here to get some help of which one to buy, not someone to tell me that im wasting my money. I bet you really think that im stupid.
