What would happen if Intel released a "triple-core"?
TheELF
4,026
753
Adding cores makes sense when you have weak cores and you are targeting workloads than can be spread out,so tablets smartphones consoles,yeah it makes sense.
If you have two strong cores that already can take care of anything you throw at them and these two cores can double the performance at major workloads people use everyday like general multitasking and games then you don't need to needlessly make the cpu more expensive, especialy if you already have a faster cpu with more cores in your lineup.
Ulocking it or giving it faster clocks from the getgo would give you more for less.
yottabit
1,479
505
Only AMD and VIA managed to disable one core... and VIA used the SAME system Intel used...... sadly even cores can't manage propperly.
I'm not sure if I'd say AMD and VIA "managed" to do which implies Intel couldn't.
Weren't the AMD 3 cores actually 4 core CPUs with 1 core disabled? If so then it was probably in their best interest to produce them as it was likely a case of improving yields. Remember most of those CPUs were unlockable but not all of them, because some likely had bad defects on that disabled core.
Has anyone ever produced a native 3 core die for PC? I don't remember that happening
Yuriman
5,530
141
I wouldn't have minded an "i5" that was 3 cores + HT, rather than 4 real cores. HT is generally worth about 30% so multi-threaded performance would be about the same. Intel isn't likely to do this though, because they'd need to move from two (mainstream desktop) CPU lines to three, which would cost more, and any die size reduction on the new "i5" would be offset by that, preventing them from being cheaper.
Yuriman
5,530
141
Hyperthreading is worth 30% in benchmarks that are supposed to use every command a core can give you,so exactly the opposite of what hyperthreading was made to do,in games and general usage it can give you 80-100% more speed.
True, being able to handle more independent instructions in hardware has a lot of value, as can be seen by the Pentium vs i3 benchmarks:
Zodiark1593
2,230
4
Core i3: 2C 4T
Core i5: 4C 8T
Core i7: 6T 12T
Should have been this way from the beginning.
Apr 30, 2015
131
10
There are a couple of possible reasons why Intel might drop hyperthreading in server chips.
One is to simplify power-gating, and the other is to facilitate the separation of tasks, onto physically separate cores; the latter could be attractive for security reasons; the hypervisor would allocate tasks per-processor core, supported by silicon design of the SoC.
If they did drop hyperthreading in E3, E5, E7 powered servers, then this could cause them to do the same in desktop chips.
In that case, having 2,3,4,5 etc cores could make sense.
This is highly speculative, of course.
