Had a toilet that wasn't filling so picked up a ballcock to replace. That helped and the toilet tank is filling, but it is filling VERY slowly. I took off the ballcock valve just to check water pressure, in other toilets it will stream out of the ballcock and almost hit the ceiling if I let it.
On this one the pressure is so low the water only rises about 1 inch above the ballcock. Took the supply line off the ballcock and tested into a jug. Sure enough I'd be lucky to get a gallon a minute out of it.
Any ideas? I replaced the supply line already (the hose from the valve to ballcock). Water pressure in the sink and shower are fine. Overall house pressure is 60 psi. This is on the 2nd floor however, other restroom doesn't have this trouble.
My only guess is something is clogging the in wall plumbing on this one outlet.
