what would cause a system to randomly turn on?
flawedecision
291
Last night about 10 minutes after I shut my system down it just fired back up for no apparent reason.
What would cause this?
BCYL
7,803
Is your PC connected to a network?
Check if you have wake on LAN or wake on Ring enabled in your BIOS... that might be the thing that's waking your PC up...
My Dad's PC used to turn on whenever the phone rings... turns out it's because he has wake on Ring accidently enabled...
flawedecision
291
Well it is connected to a switch which feeds to another machine and then the switch to a router to the net...
I've never seen this in my life... the system I just built... however I've never seen a system randomly turn itself on.
BCYL
7,803
<< Well it is connected to a switch which feeds to another machine and then the switch to a router to the net...
Then maybe it's Wake on LAN... go into your BIOS settings and make sure Wake on LAN is disabled...
microAmp
5,988
110
<< Last night about 10 minutes after I shut my system down it just fired back up for no apparent reason.
Poltergist??? ;)
SinNisTeR
3,570
my old comp started doing that.. kinda funny. it turns on after 30 mins. i have to check on that wake on LAN next time. thanks
