flexy
I have a Gigabyte GTX 660 TI 2X Windforce
The first picture is pretty much the setup I have. I also have mounted a 120mm fan right there where he has it, on the side, bottom of case blowing right over the 660 TI HSF.
My question is whether it would be better for cooling to mount a 80mm right at the door (see 2) (sucking air in through the opening), rather than the 120mm inside because the 120mm is approx 1.5" from the opening in the side panel?
Do you think it matters? ALL TWO fans (the internal 120mm plus a 80mm wont work because of clearance, just wanting to know which way to cool might be more effective.)
Alternative: Mounting 80mm at the side panel (lower openings) and blowing air OUT????
