what would be best way to clean a dirty fleshlight?
Hugo Drax
5,647
47
I have a Fulton MX-991 which I swapped out the crappy incandescent bulb with LED but it still seems iffy, ie the light is intermittent I shake it.
I suspect the switch is dirty but I cannot get to it, can I use electronic contact cleaner without damaging the plastic? WD-40, CRC etc.. sells such cleaners but not sure about the plastic. anyone here fix such an issue?
Jeeebus
9,181
901
why would you clean a fleshlight? half the fun is all the residual shame it is carrying with it. double fun if it's someone else's shame.
Reactions: ImpulsE69
Carson Dyle
8,173
524
Ultrasonic cleaner. Keep them clean and those things will last forever. I'm thinking of getting a black one.
ringtail
1,030
34
A mother's spit, and then wipe with the corner of her blouse.
Spit gotta be that of a TRUE M O T H E R. It cleans other shit too....something 'bout GOD's design.
Guy spit just flat does NOT work . . . gotta be the MOTHER's spit.
Yeah, sad but T R U E!!! So bank that as another FACT of LIFE you learned here (it's also mysterious and TRUE!)
blankslate
8,748
537
91% Isopropyl Rubbing Alcohol should be enough to clean the contacts without too much trouble. And it should dry fairly quickly.
If you need something more effective then
http://store.caig.com/s.nl/sc.2/category.188/.f
something from Deoxit is very effective for cleaning contacts. I have used the pen applicator before and found it a good application method of course ymmv.
the manufacturer claims safe use with plastics
For O-Rings a thin coat of Silicone based grease like the one you can buy at NAPA or other automotive stores used in a thin coat can help with water resistance.
https://www.napaonline.com/en/p/BK_7651346
if you only use it for maintaining flashlights you might find it a bit much but it also helps protect the rubber weatherstripping on car doors and trunks
avoid petroleum based versions as they can damage rubber.
Hope that helps.
______________
