What wire gauge for Klipsch Ultra 5.1?
Oct 20, 2005
10,978
44
I need some longer speaker wires. Is there a recommended gauge for this set of speakers?
It's only the rear two speakers that need longer wire. Once I find the right gauge, I will buy from Radio Shack.
Any advice is appreciated. Thanks.
0roo0roo
64,795
84
do the new klipsch have headphone connectors on one end? radio shack also has solderless plugs.. easy screw on terminals:p
mrSHEiK124
11,488
I do know the older Logitech Z's have RCA cables instead of speaker wire (Logi changed them towards summer 05). Looks like the Klipsches still have normal speaker wire pic
0roo0roo
64,795
84
ah seems they wised up. earlier klipsch had headphone plugs on the speaker end, a stupid design. the sub had normal connectors. very important for surround systems not to limit you on wire choice and length..routing surround wires is always a pain
remagavon
2,516
mute line in?
Done that.. it does it even without a source connected. The pots don't sound dirty at all either.. I have no idea what happened. One day I just started hearing it out of nowhere, and it's been there since. I usually use headphones partially because of that, heh.
ManyBeers
2,519
mute line in?
That hum you here is explained at Klipsch's website if your interested. It is normal
slpaulson
4,412
13
My 5.1 ultra system has a low hum when I turn it on. Anyone know how to fix that? :p
Have you tried it on a different wall socket?
Mine doesn't hum at all...
As far as the wire, I replaced mine with 16 gauge. I can't say I noticed any difference.
remagavon
2,516
Not recently, but I believe it's on a line that is power conditioned (filtered). I'll probably give it a try when I get un-lazy.
