what will give me better performance
biohazard2
Banned
May 1, 2000
872
I run cad, 3dstudio max, LOTS of games like diablo II, aoe2, UT, Q3, and rainbow 6 and watch DVD movies. I'm wondering if I'd be better off with a 64mb geforce1 DDR or a 32mb geforce2 (either a 64mb asus 6800 or 32mb 7700). Suggestions?
Duckers
2,089
I would suggest you get a Prophet GTS II 64MB for $400. If you think that is too expensive then you might want to wait for the GeForce 2 MX which is going to be around $120
Pariah
7,357
20
If you're using StudioMax, you should be using a professional level 3D board from Elsa (not a quadro), 3D Labs, or the like.
Goi
6,770
7
Pariah...I thought the GeForce and above nvidia cards already outperform other professional cards from 3DLabs, etc? At least in the ViewPerf/Spec and other benchmarks. Dunno about 3DStudio MAX though.
Also, he also mentioned he plays LOTS of games, which includes UT, Q3 and rainbow six. I don't think 3DLabs has any cards that can handle these games satisfactorily.
Finality
Get a GeForce DDR for about $220 or a GTS for $270. You can stick some hacked drivers onto the DDR and it will run exactly like a Quadro.
The only difference between a Quadro and the DDR is the drivers. With the Quadro drivers being the best for 3d modeling etc.
Take a look at reviews around the net for a Quadro kicking the $1000 Oxygen cards around :)
I'm not sure if the Quadro drivers are optimized for gaming but all that is required is a simple driver change :D
