What will be the load carrying capacity of a 18mm thick shuttering plywood?
Does this question helpful to you?
  • Total voters
smilecool
E.g. If it is supported 900mm center to center with a wooden plank then how much load it can carry without any deflection. Load will of cement concrete having density of 2500 kg/cubic meter approx. Consider the plywood as filmface with density of approx. 1 gram/cubic centimeter.
FeuerFrei
9,144
929
Consider painting the plywood before shuttering any building with it!
Unpainted plywood is such an eyesore!
BurnItDwn
26,335
1,846
This question does not helpful to you?
I believe the answer is 3 goats and a black hole.
13,617
It should be able to carry it's own weight, and then more weight. I'm not sure how much more weight though, probably a decent amount. At least twice it's own weight. Maybe even 10 times.
Chaotic42
34,599
1,759
Your joke has an awkward setup, hopefully it pays off.
I don't know, Smile, What will be the load carrying capacity of a 18mm thick shuttering plywood? E.g. If it is supported 900mm center to center with a wooden plank then how much load it can carry without any deflection. Load will of cement concrete having density of 2500 kg/cubic meter approx. Consider the plywood as filmface with density of approx. 1 gram/cubic centimeter?
nakedfrog
62,040
17,820
It already did, we got a pic of a girl doing a plank with a goat on her back. I think that makes the thread a success.
