Relatively few buy Ultra and Corsair, while Huntkey in its rebranded forms is very common. They're a top supplier and one of the most plentiful if not most plentiful coming out of China.
Relatively few buy Corsair? What?
I probably should've worded my post differently. By "who buys these?" I meant that Huntkey and Ultra are not popular among users who want a quality unit. Corsair, on the other hand, is.
The point being - you should keep in mind how power supplies are spec'ed and designed. Don't assume that just because you add 200W to a power supply that you're going to get 200W where you want it. It was true when I first wrote it and it's still true now. You should shop and read reviews and keep in mind how the power supply is designed and what quality the power supply is and how that company measures things.
Funny how you assume I don't read PSU reviews.
The mere fact that +12V is almost all of the power a modern PC uses makes your whole point irrelevant. No one goes around looking for a more powerful unit so they could power hundreds of watts worth of +5V or +3.3V hardware.
The only real world consideration is "does this unit have enough on the +12V for my purposes". This consideration is also the only one relevant to this thread - we're talking about a gaming PC. The only thing that's going to potentially make the OP want a higher wattage unit is so that it could power a more power hungry CPU or GPU setup, both of which rely purely on the +12V rail.
If you're buying a quality unit, with a few exceptions, its rated wattage will be roughly representative of peak +12V wattage. Thus, contrary to what you're saying, distribution of power between rails is not "the thing to keep in mind".
And to be more specific about the last sentence in your previous post, a 750W power supply will never have 250 more watts available on the 12V line than a 500W power supply. The only question is how much less.....
You're talking about being "more specific" yet you ignore that fact that I specifically said "around 250w more", not "exactly 250w more". Despite that, I'll prove you wrong:
http://www.realhardtechx.com/index_archivos/Page447.htm
Corsair CX500M = 456W on the +12V
Corsair CX750M = 744W on the +12V -> almost 300W more
http://www.realhardtechx.com/index_archivos/Page1418.htm
Silencer MK III series, same thing as above, but different OEM
Silencer MK II series, difference over 300W between 500W and 750W units, made by Sirtec
http://www.realhardtechx.com/index_archivos/Page673.htm
Antec EA-500D Green = 444W on the +12V
Antec EA-750D Green = 750W on the +12V, again over 300W difference
First of all, you said my information was incorrect, and I was correcting you. What I said was true, regardless of the fact that some power supplies don't drop much on the 12V line.
I said it is incorrect to think that you need to keep power distribution between rails in mind when considering a higher wattage unit. It is a non-issue, as explained above.
