It really doesn't justify the cost jumping from an Eheim 1250 to an MCP655.
If you already have one, keep the Eheim.. if it's a first-purchase, grab the MCP655.
@Aigomorla
If ANYONE would like, they can buy a Peliter which will 'TRASH' CoolITs setup
😉 Peltiers are relatively inexpensive [30-60 dollars, tops], they just require another PSU [the high wattage ones, anyway.]
You don't need a 440W Peltier... it won't do any better than a 226W Peltier, if the amount of heat being generated/removed is the same. [For say a 955EE, you'd need a 440W peltier to keep it cool..... but a 165 will do just fine with a 226W one
the Freezone boasts the ability to remove over 200 Watts of heat in a simple to install design
So, 226W Peltier [most likely]. Easily availible for ~40 dollars at DangerDen [
here].
Please do a bit more research before OMGZ0RZING!21231 a product.
And, you run into the issue of not being able to cool the GPU, which is also a major factor in most water cooling systems (it is actually rather pointless to cool a CPU and not a GPU, IMO. If you're going to run water, run it in the entire system... I ran without a GPU block for a while, and looking back it wasn't the brightest idea considering the potential I had at my feet]
So, I'd stick with a standard 2 blocks, 1 pump, 2x120mm rad for now.
If later on you get a bit more enthusiastic, you can grab a peltier. But the cost really doesn't justify the performance/electricity bill
😉 [For now, at least. Until I get the bug again :|]
--Trevor
