- Nov 8, 2012
- 20,842
- 4,785
- 146
House came with standard gas-powered 2x 50gallon tank heaters and are now about 10+ years old.
I'm seeing a large array of different kinds now - tankless ones, hybrid ones that uses the surrounding heat, and more. I'm looking for some good opinions on which to go with.
I hear how efficient tankless ones are - but my plumber has been warning me that tankless ones are also more expensive to install (requires some changes in piping potentially + bigger gas line installed) - and also says it requires more maintenance that is much more expensive since they are much smaller and more complex.
Anyone here go through this? I've also looked into the Hybrid ones - but since I'm currently on gas ones, it's kind of hard to switch to those that are more electric without getting some re-wiring in our attic-space.
If it helps here's a breakdown of current situation:
- I'm out Texas area - basically 8 or so months out of the year are excruciatingly hot.
-The remaining 4 months though are significantly colder - so not sure how much of a difference that makes when it's 30-60 degrees for a few months
-Current water heaters are 2x 50gallon tanks. They are located in the 2nd-story attic.
