What voltage should i have going to my 2500+?
Blackroot
529
Question is in the topic, it is on stock atm, i will overclock to 2.2ghz once i get a new video card however.
Blackroot
529
my mobo has it on auto, should i go into bios and set to 1.75 or something, how do the automatic settings work?
jlyda
70
my 2500+ oc to 3200+is at auto and in aida32 it says its running 1.65 @ 2.2ghz
high
Banned
Sep 14, 2003
1,431
Just set it to 11x200 and leave the voltage. Possible set your ram accordingly (didn't notice what speed you're running) but it will be fine on stock voltage. You basically won't need to touch voltage unless you want to go beyond 3200+ speeds in which case I would stop at 1.75 myself.
Spike
6,770
I am in a smiliar situation. I am going to get a 2500+ soon here and run it at 14x133 until I get pc3200 ram. If I just get some standard crucial ram (no super ocz or hyperx stuff right now, don't have the $$) can I just change my settings to 11x200? will the cpu be fine at that fsb with air cooling? just curious cause I really want to run at 400fsb.
oh, in case it matters I am using a Abit NF7-S rev. 2.0
My psu is an enermax 350watt, will that be enough?
thanks
-spike
Spike
6,770
btw, what is a normal vcore? I am looking at the mobo monitoring utility and it says my vcore is at 1.74 right now... I have never changed anything so I always assumed this was normal, is it? man, for being below 30 F outside (and only 65ish inside) my puter is still running above 50 C... really annoying
-spike
jar5tyle
271
-spike
Default Vcore for a 2500+ Barton is 1.65
Edit: are you talking about your 1800+? If it's a palimino, yea 1.75 is default
jar5tyle
271
thanks
-spike
There are a lot of people running 11x200 with the retail heatsink/fan, you should be able to run 11x200 with pc3200 with no problems, maybe a little Vcore bump
Spike
6,770
thanks for the replys. yah, that vcore is with my palamino.
-spike
