As an intel stock holder I thank you.Went through 17 chips and de-lidded them all to get that chip, which is a Costa Rica 3313B414.
p95 blend is not a good heat generator, at least small fft. Run IBT and watch temp explode.1.44v on a X5650 @ 4.3 at 60C steady on air using Prime 95 blend.
Yup, AMD CPUs like their volts high. My father has an Athlon similar to yours (don't remember exactly, as it's in a soon to be retired rig) that unlocked to a quad core. Voltages were so high that I thought the chip was defective. It stopped being able to have four cores enabled after a point, but it's still running in tri-core mode. Voltage is close to 1.4V for something like 3.7GH
One can say a lot of bad things about AMD CPUs, but they can handle some voltage alright! 1.35V isn't even close to too much for Piledriver overclocking.
Adaptive, tops out at about 1.26V during normal use, >1.36V running AVX instructions.
I've tried as high as 1.7v on my FX 9370.More interested in undervolting lately, but winter isn't too far away... ()
Sweet! Water or LN2? And what frequency did you manage to hit?
Under water. I think the setting was actually 1.65v but my LLC settings can operate a bit oddly. I topped out about 5.38GHz (not entirely stable, finished most benches, but definitely not a 24/7 overclock).
Really? I thought I'd hear some crazy number to be honest. Not that 5.4GHz is anything to laugh at.
And I think you'd be crazy to call anything that needs 1.7V a 24/7 overclock.![]()
My i7 3770K clocked to 4.2GHz hits 1.068v under load due to -0.115v offset.
^ Lottery CPU
0.1V difference? What the hell? On my machine running AVX (Or really anything that really pushes the CPU to its limits) will result in 0.02V being used.
So your auto voltage would of been 1.183v , what LLC do you run , i take its not auto or lowest setting .
LLC 4 IIRC (1 being highest, 5 being lowest in BIOS scale), setting to LLC 5 has weird behavior.
FWIW I also only see ~0.02V difference when running Linpack AVX2 on an i7-4700MQ, 172GFlops at 20000 size. ~3.5GHz 4 cores ~1.000V adaptive. Biggest problem is cooling as Linpack pushes the power at over 1.6x TDP.
Haswell does ask for water...
Just got my 5820k stable at 4.5ghz 1.275vcore, but that was running prime95. It does heat up to 80c on my h110 and I have to set it the fans on high... but it cools down from there
Never goes over 80c and thats after an hour of running prime95...
I am gonna try that realbench you guys were talking about...
