What VGA cooler is better for AIW X800XT AGP
imported_xeno
Zalman VF700-CU-LED Aluminum Copper
or
ARCTIC COOLING ATI SILENCER 4
and which will fit on the AIW X800XT ?
ty for your time and help
Can't say totally for sure if the Silencer will fit because an AIW card might have something like a TV tuner protruding too far, but the Zalman should definitely fit. I couldn't get the silencer to make good contact with my 6800gt, it makes contact with all your RAM chips and the GPU at the same time, so if the heights are uneven you can run into problems. Zalman works great.
