what tools do i need to replace a compressor
Status
Not open for further replies.
Gibson486
18,378
My mom's fridge broke....she said she wants me to fix it. I have no idea what tools i need to do this. As an engineer, I told my mom straight..."I have no idea how to fix this". She just reposnded. "Well, if it works, it works. If it doesn't, I'll just buy a new one....no big deal".
This is all i know:
I may have to recharge it, so I may need a r134a recharge kit.
Gibson486
18,378
that is what I said, but she insists that I do it. I mean, I have no problems doing it (I like taking stuff apart).
Gibson486
18,378
Originally posted by: Insomniator
Tools needed:
credit card and access to place that sells fridges
:p
that is what I said....hahaha....it's an industrial fridge though (ones with glass window), so those are not cheap.
hanoverphist
9,867
23
just start taking shit apart until you come to something you dont have a tool for...
when you have a kitchen with no counter space due to parts and warm food, tell her to buy a new one.
PottedMeat
12,363
475
Uh do you even know if its the compressor?
If you do swap the compressor won't you need gauges and hoses and manifolds and shit?
Squisher
21,204
66
Tools needed:
:p
The freon in the system needs to be recovered. This requires specific equipment.
They might not even rent this type of equipment without the correct certs that show you have the training to use it. Call a repairman, they might give you an approximate quote over the phone. btw-how can you say it is the compressor without some diagnosis?
Dirigible
5,961
32
That.
I fixed a fridge once by taking some bits off and then banging on other bits. Only worked for a week, but still counts.
Just take some stuff apart and mess with stuff for a while. It'll be fun!
Gibson486
18,378
Tools needed:
:p
because the compressor is not even working. I was there when it died. It just made this woerd sound and it just stopped. Next morning, the fridge was no longer cool but everything else worked. Looks like I may need a permit to do this because of the freon. I may just say screw it and tell her to buy another.
Pigiron
Vacuum pump
Torch and solder
Copper tubing and tubing cutter
Pressure gauge manifold
Refrigerant (around here you have to be licensed to buy the 24lb-30lb bottles)
Scale
That's all I can think of off hand. You would be better off hiring someone to fix it.
Miramonti
28,653
100
Hire a repairman if she doesn't want a new one. I'm not sure you want to fvck with freon for the first time just because she tells you to.
PlasmaBomb
11,636
Ask Sea Moose...
You probably need a license for the refrigerants... at least here you do...
Gibson486
18,378
I told my mom to just hire someone else. You have to know your limits, and well, this is well beyond them. I was gonna tell her to buy a new one.....then i saw the prices....$5k each.
Status
