What to rub CPU with
ExcaliburMM
613
www.Staredit.net
Directing a friend of mine in the cleaning of his CPU, and application of fresh thermal paste. He has some 99% rubbing alcohol on hand but he has no coffee filters which is what I usually use. Any more common substitutions?
evident
12,122
741
i've never used a coffee filter before. i normally use cotton swabs/balls and apply new thermal paste with a plastic lunch bag on my finger.
Idontcare
21,110
59
Originally posted by: Denithor
I use cotton balls or an old tshirt.
Yeah, for scrubbing off the old paste there is no harm to come from using fiber shedding materials (seriously).
When done cleaning, hold the cpu at an angle and give it a good douse of the rubbing alcohol to physically flush away any fibers that might have been left on the surface from the scrub portion of your cleaning process.
Then shake off the excess and leave to air dry. The alcohol will evaporate in less than a minute, clean and fiber free.
If doing this results in visible (discoloration) signs of residue remaining on the IHS after the alcohol evaporates then that is to be interpreted as proof that the IHS wasn't really thoroughly cleaned during the scrub/rinse cycle. In this case, repeat until no longer necessary...
exar333
8,518
8
I can think of a few things you SHOULDN'T be "rubbing" your CPU with...
*wink*
Idontcare
21,110
59
*wink*
Thank god intel went with the pinless option :shocked:
taltamir
13,576
old underwear made of 100% cotton. clothes are the only clothe that is high enough in quality, and underwear is the higher quality of them all, its soft, its absorbent, it leaves NO fibers.
ch33zw1z
39,629
20,218
tell that to my ass! free ballin 5 life!
I use qtips and rubbing alcohol to clean off old thermal paste
magreen
1,309
Maybe if you wore underwear you wouldn't have that problem.
BonzaiDuck
16,374
1,905
Sure -- I use underwear rags. I even use paper towels -- sometimes, I use toilet paper.
Talk about being anal-retentive, or picking fly-s*** out of pepper for lapping a CPU!
:laugh:
Denithor
6,298
23
*wink*
:shocked: is right. Ouchies. :laugh:
