What to expect with a 1900+ and 6800?
fisheye
63
My friend picked up the $199 6800 at compusa (actually, I was the one waiting in line - he had to work).
His CPU is an xp 1900+. An upgrade is imminent, to an xp2700-3000+. Until then, how much impact will the slower CPU have on gaming performance?
I would have installed it already (at about 7am on friday!) but his PC is currently unoperational for unknown reasons (likely RAM).
Seeing how he's coming from a radeon 8500, I think he's going to be impressed :)
Jun 14, 2003
10,442
it will be good in the sense of free aa an af, that cpu is gonna hold it back alot i think, 6800's are cpu limited some times even with the fastest processors available
i think u can expect games like ut2004 to have the same frame rate regardless of resolution becuase the rest of the system jus cant keep up, the cpu upgrade couldnt come sooner
WT
4,816
59
You will definitely be able to turn on AA and AS and crank them as far as you want. This eliminates the 'jaggies' from games and will make for a much more realistic image. 2500s are cheap, so he bought a great card which will play any games out very well ... easy enough to upgrade to a Barton and o/c it to fix his bottleneck.
zerocool84
36,041
472
i had a 2000+ chip and now i have a 3200+ chip and let me tell you, it helped so much jumping to those speeds. i used to choke in hls and cs source cus i was way cpu limited and i have a bfg 6800 oc and would only run it at 1024x768 and i would still lag. trust me, ditch that old chip and get a newer much faster one
