Its almost April. Time to do the proverbial Spring Maintenance. Here is a partial list. What else can be added?
Tires Check air pressure and tire tread, including the spare tire.
Body Get good car wash, under carriage wash, and wax job
Engine Check air filter, check maintenance schedule for other maintenances. Check belts and hoses for wear.
Air Conditioning Check outlet temperature compared to outside temperature
Remove from vehicle Ice scrapper and miscellaneous clutter
Check all fluid levels oil, transmission, coolant, brake, power steering and washer fluid.
Check Windshield Wipers
Brakes Listen for any brake squeaks or uneven braking
