Regarding Haswell, I was told by an Intel employee (one who ought to know) that Haswell would have the same IHS and CPU TIM situation as Ivy Bridge.
Now this was some 6 or 7 months ago though, and even if that was the POR (plan of record) at the time there is still a chance that the POR has since changed.
However I think the more relevant question is "has Intel improved on the gap height between the CPU and the IHS?" as many of you have noted this is critical in determining the thermal performance of Ivy Bridge.
Also, I want to clear up any confusions my posts in the may have created. It is true the gap is responsible for Ivy Bridge's temperature issues. It is also true that Intel could have further improved on the situation by going with an even better TIM like Liquid Ultra.
What my tests showed was that the CPU TIM Intel does use under the IHS in their Ivy Bridge CPUs is on par with that of the quality of NT-H1 (itself considered to be a high quality TIM by enthusiasts).
But NT-H1 is not "the best" TIM out there, so it stands to reason that enthusiasts can likewise further improve on their delidding results by both reducing the gap height (delidding and removing all the black IHS adhesive material) and replacing the CPU TIM with a liquid-metal type TIM (Liquid Ultra has the best thermal conductivity).
From my thread on comparing
9 different TIMs with bare-die testing we can see that AS5 is quite a step back from NT-H1, which means AS5 is also quite a step back from Intel's stock CPU TIM.
Replacing the stock Intel TIM with
AS5 is a step backwards, your thermal performance is going to be worse. The only reason the temperatures did not get worse is that in replacing the TIM with AS5 you also reduced the gap height, so things are less bad and your temperature do become somewhat lower.
^ ranked from left to right in ascending order of poorer performance, lefthand side are TIMs with the best performance.
If Intel had assembled Ivy Bridge processors with both the existing gap as well as using AS5 instead of the existing stock CPU TIM then the temperatures on Ivy Bridge CPUs would have been all the worse. But if they had used something like
Indigo Xtreme then the gap would have not been a concern.
Intel could not have used Liquid Ultra or Liquid Pro with their Ivy Bridge CPUs while having the gap, the liquid TIMs would not have stayed in place so it wasn't even an option.
Bottom line is that on a delidded Ivy Bridge the TIM does matter, don't use AS5 or anything that has poorer thermal conductivity than NT-H1 as you will be taking a step in the wrong direction. Use something on-par with NT-H1 or better, with Liquid Ultra being the best commercially available TIM to use.
