- Dec 31, 2000
- 10,735
- 0
- 0
I only ask because...making sure it dosent happen again might be kinda safe.
I was driving home from a friends house. Came to an intersection. Got 50% thru, lost PS and RPM's went to 0. All the dash lights went on like when you intitially start (including oil pressure) so pulled to the side of the road and put it in park. I was reluctant to restart it and go home cause I didnt know what was up, so I broke a flashlight out of the glovebox and checked to see if I snapped any belts. Didnt look like it. No massive oil leak, cause the pressure sensor would have set off the light before the engine died. Shrugged, cranked it. Engine started. No oil, temp, or etc...lights so I drove home.
I had a full tank of gas, so that eliminates the fuel pump not getting anything. And my headlights and radio were on thru the entire ordeal, so I know the battery is fine.
-PAB
I found it. I had 2 engine stoppages last night. I got in my car this morning, cranked it and the engine started but immediately shutdown. So I started troubleshooting. I popped the hood and opened my door. Door chime. Radio. Ok. Not a battery issue. I checked all the connections to the dist cap and spark plug wires. Nothing loose. I pulled the engine fuses to see if the EFI circuit was blown. Fuse = fine. Igntion fuse was OK, otherwise I woudlnt have even gotten the engine to crank. Then. It hit me. I got in and put the key in the acc position. Nothing came on. The On position. No guages, no check engine light, no AC, but I get a radio, power door locks, and a door chime. Then. I turn the key back very slowly towards the ACC position. Bingo. Lights. Guages. AC blower. Its my goddamn fscking igntion switch. The engine goes into start, and doesent realize that the key is in the on position anymore so it shuts down.
Oy. Anyone know what an ignition swtich runs for an integra? I can feel my pockets getting lighter from here.
-PAB
