What temperature is too hot?
avzay66
77
Hello
i got tbird 1ghz on a asus a7v133 mobo with alpha PAL6035 with delta fan
on asus probe when idle cpu temperature is 54-56C. Is this too hot?
A.Z.
Boonesmi
14,448
thats kinda high. but you need to remember that asusprobe shows the temp about 7-10c higher then most other motherboard's (because of the way it measures the temp) so most other boards would probably show your temp around 46c
AMD says the opertating temps upperlimit is 60c
but... if you plan on overclocking you will need to be well under the 60c amd recomends
avzay66
77
So how can i reduce the temperature?
the cpu itself is kinda old..says 1999 on it. does this have anything to do with high temperature?
I was planning on running it 133*7.5 instead of 100*10
A.Z.
Mikewarrior2
7,132
Boonesmi,
Where did you hear that? THe max operating tmep is 90-95C die temp, but max "read" temp depends on what mb and how the mb interprets socket-thermistor temp. ON an A7V class MB, 54-56C is perfectly fine.
AVzay66,
You probably won't be able to do anything to drop the temp significantly. Know that your temps are in the "normal" range for stadnard and even overclocked a7vs.
Mike
Patgod
182
so on an A7v what would you say the max read temp should be before you get out the icewater/fire ext.? :)
Bad Dude
8,464
your temp is perfectly fine. As long as it is not crashing. If the chip is hot then it's burned. So yours is still working so don't worry too much about it.
Mikewarrior2
7,132
Patgod... usually 65C is the "max" on an a7v while stile maintaining system stability.
Mike
eeut
92
To mikewarrior2. I have a TB800@1050 on asus a7v. temps..mb 31c and cpu 48-50c running rc5,prime,3dmarklooping. monitored by mbm and asus which showed same temps. vcore=1.85 vio=3.6
should i be getting higher temps?
Mikewarrior2
7,132
What bios revision are you using? And for that speed t-bird, those are perfectly acceptable(nad for an a7v, pretty darn good) temps.
Mike
eeut
92
thanks:D. latest bios 1006 which was spread around. tried 1004c-1005d-avu102a1(a7v133bios) bioses all seem to be the same. but idle stays 45c. on old bios1003? idle stays 36c weird:confused:
Mikewarrior2
7,132
Bios 1004 and later add compensation to pc-probe(asus pcprobe) readings, plus do something that messes up ACPI compliance.
Mike
darth_beavis
239
If you are really worried, you can use conductive grease on your HS and chip instead of conductuve tape. (If you haven't already) This helped me drop a couple of degrees.
eeut
92
thanks again mike for clearing it up. for A.Z. I have same hs but using y.s.tech fan w/ AS. what i did was bend my clip more(risky, and might not hear comp)cause clip seems to soft/easy to put on. where i live(central florida) it worries me of summer:frown:.
