- May 16, 2008
- 3,180
- 0
- 0
Firstly to avoid the idea that this is a brand thing, it isn't meant to be. Theoretically we are examining two cards from the same manufacturer/model.
Say reference vs. custom or possibly custom vs. custom.
Reading past the marketing, what matters most for the stability and perhaps overclocking/overvolting and long life of a graphics card?
As I browse e.g. 290's (but that doesn't have to be the focus of this discussion) I'm curious what cards are best for OCability/ov/stability after your remove the silicon lottery factor. When looking at e.g. the sapphire Tri-X, the reviews mention that it's basically better cooling on the reference board. The reference card is obviously overwhelmed by the hot core and therefore the clocks are not necessarily consistent.
Some points which are mentioned often are the fan/cooler, VRMs & cooling, power phases, solid capacitors. What else should a (relative picky) buyer be paying attention to (and briefly why).
Clearly the Lighting and classified are the most revered cards but are the e.g. SCX and Gaming essentially the same thing as the higher end cards to an air cooled user (assuming some silicon binning may be in the Lightning/classified)?
Obviously warranty is another critical point but it doesn't mean you can't overclock etc.
A starter list:
Cooler/fan & effectiveness vs. noise
VRM cooling
Power phases
Solid capacitors (are there even others anymore)
Chokes
Coil whine (reputation?)
Heatpipes
PCB flex
A starter list:
VRM cooling
Power phases
Chokes
Heatpipes
PCB flex
