What tablet are you using?
ChronoReverse
2,562
31
1-2% per hour in CM7 is not the same as webOS. I left my Touchpad on the floor next to my bed for 8 days and I picked it up and it was still at around 40%. It synced email and Facebook for 8 days straight. It will NOT last that long on Android.
You get 1-2% per hour, I get <1% per hour. Overnight 8 hours with wifi on drains just about 7% for me. Sounds like you're on Alpha 3 instead of Xron?
I certainly didn't get 8 days on WebOS with wifi turned on. If I turn off wifi sure, but with it on it's about the same (well, it's better, being closer to 0.7% per hour).
Still, the difference is academic since the Touchstone makes sure it's fully charged when I pick it up and 4 days of standby is plenty sufficient (although Facebook on the PC is a much better experience while the WebOS one is pretty but useless).
Apex
6,511
www.gotapex.com
Had an HP Touchpad and tried it both with CM9 and WebOS, now it sits gathering dust while I use my iPad 2 everyday. Say what you will, iOS is better than both of them for just working out of the box.
Nice! Have link on instructions on how to download & install CM9? Thanks you.
MrX8503
4,529
For me, none so far. Anything non retina or lower than 300dpi is too blurry for my tastes. I may finally get one if the iPad3 is retina or another tablet sporting a 1600p screen.
ZetaEpyon
1,118
Nook Color with CM7.
I intend to replace it (and my old Dell Mini 9 netbook) with a Transformer Prime. Probably not until ICS is rolled out for it, though; I'm not in a rush.
HateMeAlways
35
Just received a Touchpad I won in a contest held by Mashed Deals. Feel a little obligated mentioning them since they picked me and it is a 32gb model. I oc'd to 1.5 and installed some tweaks, it's not bad. The touch screen takes some time to appreciate. I like it for what it is and can do, but my iPad 2 is without a doubt better. It's the availability of apps. If the touchpad only had the apps..........
ponyo
19,688
2,810
Touchpad has apps...too many in fact.
zoiks
11,787
Tablets are a waste. I had the transformer and my wife has the ipad2. Typing on one is a friggin pain. Virtual keyboards suck for typing. It's okay for playing simple games and checking facebook and email. Typing a long email is pretty shitty.
Overhyped and overrated.
