Originally posted by: ScrewFace
The Pentium 4 2.4GHz is a pretty good overclocker. I'd try for a 166MHz bus right away for 2.988GHz.
Sorry. Totally disagree. Work your way up. Maybe start @ 145 FSB.Originally posted by: ScrewFace
The Pentium 4 2.4GHz is a pretty good overclocker. I'd try for a 166MHz bus right away for 2.988GHz. You may have to raise the CPU voltage some to make it stable. Make sure you use a good heatsink-fan combo not the garbage stock one that comes with the CPU. You want a copper cooler with thin copper spokes. Good luck!![]()
Originally posted by: EdipisReks
i never take it slow, myself. i go for the highest speed that posts and then work my way down. i find find that i am able to find the sweet spot a lot faster that way. of course, if i had to actually clear the cmos with a jumper instead of just holding down the insert key when the machine powers on, i might have a different methodology. i just hope the 2.4b retail box i just ordered from Newegg is a c1 (crosses fingers).
