I want to overclock a duron 700 to at least 900 Mhz. I want to get new memory for this setup and I'm not sure whether I will need Pc133 or PC100. I understand that this depends on how fast I clock the memory or bus when overclocking, right? Well I'm not that familiar with the settings to achieve a 900MHz. Does it need to use a bus speed higher than 100? or can I just you multiplier adjustments and not need to change the 100MHz bus speed. Anyway, is it nessessary to have pc133 memory?
Thanks
-Lawrence
Thanks
-Lawrence
