Originally posted by: Captante
What chipset does your old card use?
Originally posted by: theprodigalrebel
I have no idea about your particular sound card but I do know modern motherboards have pretty good on-board sound.
And of course, you can always try both and compare.
Originally posted by: YOyoYOhowsDAjello
You probably have a digital output rather than input on your motherboard.
Do the DVDs always stop at the same spot? Maybe something's screwed up and your drive cannot read the second layer of DVDs?
Originally posted by: mercanucaribe
You can use both at the same time. You could use the Santa Cruz for output, and the motherboard's optical input for your DVD player. I'd be doing the same thing with my Santa Cruz if I didn't lose sound in games sometimes-- I think the drivers suck. My digital cable box makes a hum, so I think I'll try an optical cable instead of RCA->1/8.
No and its only some dvd movies from netflix. Mainly the rare foreign films.
Are those all region 1 DVDs?
Yeah, I use a dedicated DVD player as well, mainly just to not deal with the hassle of getting everything right with a computer setup. I'm often using my computer for some other task when I want to watch a movie too, so just using a regular player makes sense for me.
If you think it might be an overheating problem or something, maybe you should try getting more ventilation to the drive or moving it outside the case temporarily to test the theory.
Do you think it might be related to the software DVD player you're using? That would certainly be a cheap and easy thing to try if you haven't already.
Well I use VLC and it did fine, same version, on many other foreign movies but all of your suggestions are great! I am not as much of a computer geek as I use to be 🙁 I use to love messing things up and trying to figure out how to fix them. Seems like that has long been gone. I guess after dealing with computer problems for so longer sooner or later everyone gets tired of them.
If I was going to use my computer as the player, I'd get into the whole FFD show optimizations and all that jazz and I haven't really felt like I wanted to do that yet.
The only disadvantage of not using a pc or your main pc to play movies is you can't use your dvd player for playing netflix watch now movies for your big screen. You would have to use some type of tv out feature or else you would watch them on the size of your pc screen. Now if your pc screen is 42 inches or larger you really don't have any problem but how many pc use a 42 inch widescreen for their pc monitor around here?
I have no idea. How would I find this out?
Originally posted by: ribbon13
What is the model of your NEV DVD-RW? Can you check in device manager and report back? I may have a newer more capable firmware for you, and region free to boot. Standalone DVD players pale to what a computer can do. Here's a good post http://www.avsforum.com/avs-vb/showthread.php?t=719041 I personally use Zoom Player with Cyberlink's latest installed for the DVD video decoder. But I have a Westinghouse 1080P 37" screen 😛 Soon to be a snazzy Samsung 40"... god those LNS4096D's are sexy
http://www.gigabyte.com.tw/Products/Mot...&ProductID=2321&ProductName=GA-965P-S3
http://www.realtek.com.tw/products/prod...angid=1&PNid=24&PFid=28&Level=5&Conn=4
We can deduce from those two links your onboard's analog section is going to suck ass. Realtek value chip == ass. If you use your computer for mostly movies/video viewing, the HT Omega Claro is a great sound card, but pricey.
http://www.htomega.com/rgboard/view.php?&bbs_id=soundcards&page=&doc_num=8
Your question earlier, there are two types of common consumer digital audio connection, TosLink and or RCA over S/PDIF protocol.
http://common.ziffdavisinternet.com/encyclopedia_images/SPDIF.GIF
