What software do I need to measure heat from a Duron on a K7T Pro2 ??
SnoopyDog
Hi there
I have just installed the K7T Pro2 instead of the old K7T Pro, which means that I am now able to O/C my other system.
Which software do you guys recon I should use to measure the heat from the Duron 600 CPU ?????.
I have tryied with normal voltage and I O/C easy to 800 mhz and more. But I have stopped for now due to the heat increasion that there will be when O/C. I know that I just can go into the BIOS and read the heat gage there, but I whant another way.
Cheers,
Snoopy Dog
