What size fan for a radeon Le heatsink
<< Hehe, I have no fan on my heatsink. I think I should get one because its like burning to the touch someitmes. >>
its a radeon LE, no one has a fan on it unless they add one. like i said, you should be able to go as high as ~183 constant with just stock heatsink...maybe even higher.
plus, realize you lose a pci slot if you attach say a blue orb.
booty
<< are you sure ? the heatsink is like burning to the touch when I touch it someitmes. Does yours do that ? >>
Yes all Radeon LE's run hot and yes all Radeon LE's only have a heatsink.
