I am trying to find the size of an electrician's die to cut the fan hole in my case. It would be alot better than a holesaw..but if someone knows the size of the holesaw used for the 80mm and 60mm cut outs that would be cool too.
Go to a hardware store and find the hole saws. Most have the "mm" listing as well as the inch listing on the package. I bought Milwaukee hole saws and they all had the "mm" size listed. The electrician sets I saw didn't have the proper sizes BTW. Good Luck!
