- Mar 7, 2002
- 1,101
- 0
- 0
Originally posted by: Tiamat
"does it fit"
Seriously, my apartment window has bars behind it, and only 1 AC unit that I found could fit in the limited depth.
Also, How big is the room you are trying to cool.
Energy ratings are important if you pay the bills.
Haha... 97% efficient? I'd like to see how they calculate that number, which is thermodynamically impossible.Originally posted by: supafly
It actually went down. There used to be a big, old A/C in the middle room up here but it didn't cool my room too much, so just putting a small one in my room and turning off the other one was an improvement.
The energy guide tag on the new unit says it is 97% efficient and it costs $35/year to run.
I would look for (in this order):
1. Proper size
2. Efficiency
3. BTU ability
Efficiency is a higher priority for me than the BTU because a lesser BTU AC unit really can cool a larger room - it'll just take longer. But really, this order depends on your budget. If you have more money, you can buy the larger (read: more expensive) BTU unit and pay a bit more in cooling costs every month.
Thats sorta expensive maybe. I think walmart's bottom end 5,000 btu is $80-85.Originally posted by: RossMAN
CostCo has some great deals on nice Sharp and Panasonic a/c units starting at $129.
"does it fit"
Mine's the cheapest one they had at wal-mart. It's made by goldstar and it does a damn good job cooling my room.
Originally posted by: kaymin
Make sure you look at the energy it uses. The cheapest one usually requires double the cost in electricity.
The one i bought costed 50 dollars more than another model of the same brand Kenmore. BOth had the same BTU, etc. But i bought the expensive one because the energy requirement was literally HALF.
impossible. they all meet minimum energy standards, and one that is $50 more will NOT be that much more efficient.
