What should I do after buying a used car with no maintenance records?
Status
Not open for further replies.
LeetViet
2,411
How much should I expect to pay if I do it myself and if I take it to an independent garage?
zerocool84
36,041
472
Umm take the car to a reputable shop to get it inspected. How do we know how much you'll have to pay for anything? We don't know what's wrong with the car.
Bignate603
13,897
Oil will be cheap, but spark plugs and wires can vary quite a bit depending on the car. A 4 banger that takes copper plugs and has easy access to them costs very little. A V8 that uses platinum plugs and has plugs that are hard to get to could easily cost 5x as much or more.
You have no idea how much it will cost until you know the exact kind of car and get it inspected to figure out what's wrong. The best thing to do is pay a mechanic $50 to inspect it BEFORE you buy it. If it has issues then you just walk away and look at something else.
zerocool84
36,041
472
Originally posted by: LeetViet
Sorry zerocool84, I meant things like oil, spark plugs, etc.
I'm thinking more preventative than reactive problems.
Go take it to a good mechanic first. Always the most important as they can see things coming that regular people can't.
zinfamous
111,556
30,777
yeah.
pay $50-75 for inspection before you purchase.
I almost had a pretty sweet deal on my Boss's 2000 Altima, 74k miles, for $3k.
took it in for inspection, came back as audible engine knock. 3 quarts low and oil never changed :(
I noticed it as a slight "sputter" when driving it downhill or coasting in 2nd, getting used to the clutch. I had simply chalked it up to the car being abandoned for the previous 5 or 6 months. Oh well.
evident
12,092
705
yeah.
wow, oil never changed for 74k miles? ::shudder::
Status
