What sample rate and bit depth should I use?
lollersharts
I discovered this setting in speakers headphones properties---->advanced, and each one makes my music sound way different. I'd use the highest one but it kinda sounds like shit. Any info on what to use? It defaults on "dvd quality (16 bit, 48000 Hz)."
Thanks
Normally I would use whatever is highest(the best if the speakers can take it), but that's just me. Keep the rate over 40khz though at minimum. (Actually the highest frequency you can hear times 2).
it defaulted to 48khz ("dvd quality") and 44.1khz is "cd quality." I kept it on 44.1 per your recommendations, but i was leaning that way anyway. sounds pretty damn similar imo.
I use Studio Quality on my HD Realtek on board, 24 bit 192000hz.
LOL. If you played back a cd at that rate, it would sound like the chipmunks with their nuts in a vice - plus, songs would be less than a minute long.
Doesn't quite work like that for any non junk stuff....
It's about what frequencies it cuts off at, not the rate at which it is played.
BS.
Best case scenario is it would have to upsample, and you can't hear anything above the cd rate anyway. Besides, it can't make a cd any higher quality, even if it upsamples.
BS.
I'm sure you both know what you're talking about and are really arguing over nothing lol
Upsampling - where it's actually done - is like digital zoom. The inbetween stuff is interpolated and doesn't really make much difference, although some people like to think it does. If it's audio, keep it 16-bit/44.1khz.
Yeah, I recommend keeping it in the original bitrate and sampling rate. The exceptions are with MP3's (use highest bitrate that your soundcard or source can actually handle but keep the sampling rate the same as the original) and if your soundcard does internal resampling. A lot of soundcards will always resample the audio (usually to 48 Khz) internally when they apply any kind of processing (3D effects, EAX, or just for shits and giggles (Thanks Creative)). For these cases, you may want to set it to 48 KHz just so you do not unnecessarily make the soundcard upsample to 48 KHz and then downsample back to 44.1 KHz for analog or digital output (your speakers don't care). In addition, some people feel that some software resamplers (Like PPHs for Foobar) do a better job than the hardware so they upsample the stream to 48 KHz instead of letting the soundcard do it.
But this has been improved with Vista and Windows 7 with the incorporation of WASAPI (earlier there was ASIO too but that was always a bit dodgy if your sound device did not have ASIO drivers). WASAPI can allow you to directly output the sound to the output device and avoid some of the Windows software layers. I think this is mostly helpful for digital outputs since it keeps the digital feed unmolested but if you are using analog outs then it probably still goes through the soundcard's processors.
