I?m building my first rig and have a question about where to plug the fans. Here?s what I bought:
Case: Antec PlusView 1000AMG
Mobo: Gigabyte GA-8KNXP
PSU: Antec TrueBLUE480
Fans: CoolerMaster 80mm fans (x5)
The Antec case holds 5 fans and I bought 5 coolermaster fans so they would all be the same (and removed the two Antec fans it came with). The Antec power supply has a 3-wire plug for the mobo fan sensor and two 4-wire "fan only" plugs. The Gigabyte GA-8KNXP has 3 places to plug fans; one for the CPU fan (obviously), one labeled Power Fan and one labeled System Fan.
I plugged the 3-wire fan monitor wire from the Antec power supply into the Power Fan plug on the mobo. I plugged the two rear case fans into the power supply Fan Only plugs which I assume will be controlled by the fan monitor from the mobo. I plugged the remaining 3 fans (2 front and 1 side) into the System Fan plug on the mobo.
I haven?t turned the rig on yet (I?m waiting for my memory to arrive tomorrow
). Did I hook the fans up correctly or is there a better way? Thanks in advance,
