Running my fine with a Aerocool Aero Power II, and the Thermaltake 20-24 Pin connector.  It been working great and looks great with solid rails, however I have not directly measured them directly.
			Originally posted by: GodLovesPunk12345
So looking at PSUs now to replace my current pos, the modular feature looks really nice. I think I'm set on the OCZ ModStream 450w, everything looks good. Just wondering, its a 24 pin main connector right?
Edit: And is it dual rail or whatever I'm reading about now? From what I've read its not "that" big of a deal, but I think I'd prefer to stick to single rail.
Originally posted by: hundesau
geze, why the heck u all running 500+ even 600+Watt psu`s? defenitly not necessary, u can run a sli system with 420Watt already, if its a good psu like tagan or bequiet. I personally do care for how high my elctricity bill is, thatswhy i bought AMD Winchester and not Intel and so i wont now buy a 600Watt psu that will only run at 40% usage with a resulting very bad input-output power relation. Its not cool to have 600Watt and only using 270 of them. Makes no sense and costs real cash for electricity. just needed to mention that.
Originally posted by: Auxano
Enermax Noisetaker 701AX. (600W)
Overkill but I was able to get it for $110 AR. Runs very quiet and cool.
(The blue color also matched my case!)
Originally posted by: quik
How many watts does a 7200 rpm hd use roughly?
There was a website that used to add it up all for you, you just picked how many hds etc... and gave you what size power supply was needed. Anyone have that link..? I couldn't track it down on google...
Thanks
Thanks
Where did you get it for $110?
Originally posted by: AlexBmur
I am using an OCZ ModStream 450 watt PSU, and it works great with my A8N-SLI. I highly recommend it.
Originally posted by: Commando8
Anybody know anything about this power supply:
http://www.compusa.com/product...code=317509&pfp=SEARCH
My friend has his a8n-sli and one 6600gt and will not be overclocking. He is intent on not spending over $50 on the PSU (I keep telling him he's insane). It does claim 20A on the +12V rail, so that is above the 17A minimum requirement....anyway...
