What problem to use for stress testing an overclocked Video card?
aatf510
1,811
ATItool artifact scan doens't seems to be sufficient, and 3Dmark06 loop seems to crashes even at stock speed?
What else is there to use if I want to make sure a overclocked Video card is stable?
nitromullet
9,031
36
3DMark06 is actually an excellent stabilty test, IMO. Games that push the card a lot are also good tests, Oblivion and FEAR come to mind.
Munky
9,372
Any sufficiently demanding 3D game will do. Especially Oblivion - if it doesnt crash in 20 minutes of Oblivion, chances are it will not crash after hours of other games.
jim1976
2,704
QFT. But you can always use rthdribl...
d3lt4
848
If 3dmark 06 keeps crashing it is unstable. Mine wouldn't run 06, until I got better cooling, IMO.
aatf510
1,811
But my 3dmark06 always crashes after the same test even at stock speed, and my friend has the exact same problem crashing at the exact same point. Therefore, I think it's a bug rather than my card being not stable.
akugami
6,210
2,552
I've run 3dmark overnight and not crashed. If it's crashing for you, you either have a bad card or you have insufficient cooling in your computer case. The two test I currently use are RTHDRIBL and 3DMark.
TheRyuu
5,479
14
RTHDRIBL
And the forest benchmark in 3dmark05. The one with the fairy flying around, I find it really easy to spot artifacting in that one. Also, Doom 3 and Quake 4 are pretty sensitive.
Sunrise089
882
Right. OP, just because your GPU is at stock speeds doesn't meen it cannot be bad/unstable, especially if you have a factory OC'd GPU. When nVidia designs a GPU they design it to operate at rated clockspeed in something probably like 99.99% of cores built. They know that at some point it's better to introduce some bad parts than to advertise a slower part. Then when eVGA or BFG decided to market their card factory overclocked they decide they will accept say a 99% reliability rate. There is no guarantee any user won't be in one of the small percentages with a bad card. If you cannot get your card to run stable, and have no OC issues, good drivers, and your case has OK cooling then you may have a bad card. And don't let anyone tell you to get better case cooling if you don't want to. These cards are not designed to be run in a abnormally hot case, but the card as sold should run fine under normal conditions. RMA if you cannot get it to run 3d mark at stock speeds, that's what RMA programs are there for.
akugami
6,210
2,552
I forgot to mention that bad drivers can also cause instability. Make sure you have the latest BIOS, motherboard drivers as well as video card drivers. Make sure you do proper removal of the older video card drivers. Both ATI and nVidia suck and leave renmants of older drivers behind that can cause instability. Download Driver Cleaner Pro (free software) and it will help you remove traces of old drivers. Generally what people recommend, and what I also recommend, is to uninstall the older drivers, reboot into safemode, run Driver Cleaner Pro and have it clean out your old video card drivers. Reboot and then install the new drivers.
aatf510
1,811
I am making the assumption because both my friend's watercooled XFX 7900GT and my stock cooling eVGA 7900GT crashes at the exact same point (right after HDR2 is finished) if we choose to loop 3Dmark06 HDR1 and HDR2, and it only crashes at the same spot in serveral trails and it only crashes after running for over an hour. However, if we let our cards run overnight with the 3dmark06 Demo, then our machines are fine.
Sunrise089
882
Well I don't want to tell you for sure there is anything wrong, but 3Dmark is really popular, and wouldn't any problem that caused it to crash be widely known?
biostud
20,113
7,221
could be a bad download of 3Dmark. I've had it crashing on one system too, ran everything else fine. but as many has said use RTHDRIBL, it was the one that I got the highest temps in my setup.
LittleNemoNES
4,142
Bad ram can make any app crash. So if its not artifacting and heat levels seem to be acceptable, prob bad ram. Use memtest.
