what power plugs do they use...
rh71
in South America (Rio & Argentina)... I looked it up and they mention "2 parallel blades"... so is that the same as the US ?
Originally posted by: rh71
thx... so if it says 220v, the usual european converter should work ?
As long as your device can handle the voltage and frequency, all you need is the adapter.
What is it that you're planning on using?
