Why should faster PCI bus helps Wireless Sensetivity?Originally posted by: Foxox
While on this topic, are there any PCI-E 1x or 4x network cards and do they work any better?
whoa, $220 for a 5 mile outdoor adapter? crazyOriginally posted by: JackMDS
There is No real difference between the PCI adaptors per-se.
The difference can be created by using, and placing correctly, a High gain Directional Antenna.
As an Example.
This, http://www.buffalotech.com/products/product-detail.php?productid=48&categoryid=7
Plus this, http://www.buffalotech.com/products/product-detail.php?productid=39&categoryid=8
:sun:
Originally posted by: ThePiston
i was actually considering buying it...how cool would it be to choose from 50 different signals?
Increasing Power at the receiving end usually does no too much, and in this case does not justify the price of the D-Linkis Gizmo.
:sun:
Originally posted by: ScottMac
I think you'll find some differences in the chipset used to construct the adapter.
The Atheros chipset, used by Cisco (as an example) for their cards tend to have excellent sensitivity .... but sensitivity does you no good, unless it's also very selective (able to discriminate one signal from other, possibly even stronger, adjacent signals).
I've used the 3COM (175) and Cisco a/b/g adapters (both Atheros chipsets), as well as the dlink, linksys, and some others.....they both, IMO, get better reception and seem to reject interfering signals better than some of the less-expensive NICs.
(And Jack is also right that antennas can make all the idfference in the world ... antenna design, engineering, construction (especially the matching network) are what makes a great antenna instead of a good, decent, or crap antenna).
I guess the differences are that many started their hobbyist computer?s carrier in Over Clocking, Video Frame Pushing and the current ?Silly? fetish of fancy Power Supplies. This knowledge is trying to be extending into issues to Networking and Wireless.Originally posted by: Tostada
Odd that this topic has been on the front page so long and nobody has much of anything to contribute about differences in PCI adapters.
There are just too many problems with your argument that all wireless cards work about the same.
1) The cards are often based on totally different chipsets.
2) The cards have different drivers which will have their own issues.
3) Even if you believe that the antenna is the only thing that matters, you must realize that most adapters have just one antenna, while others can have two or three different antennas. Obviously if the antenna is so important, then the number of antennas has potential to make a big difference, too.
The topic at hand is Wireless PCI adapters.Originally posted by: TostadaEven if you believe that the antenna is the only thing that matters, you must realize that most adapters have just one antenna, while others can have two or three different antennas. Obviously if the antenna is so important, then the number of antennas has potential to make a big difference, too.
May be you should read a little about what the two Antennae on some Routers, and the three Antenna on the MIMO means, and how it works before you get busy counting Antennae.
All the adapters I see with 2 or 3 antennae (not antennas? I thought antennae was just for insects...) claim that this enhances range, even when not functioning in a MIMO capacity with other adapters of the same model. Is this just hype?
I'd really like to read about this if you have some good sources. Most of what I can find is just general stuff at places like Tom's (Tom's Networking, Tom's Hardware, whatever), or the finer points of different kinds of antennas (and building your own) on wardriving sites.
Originally posted by: spidey07
sigh.
not, they @re pretty much the s@me. It is @ll driver/softw@re.
Th@t's where it would be best to stop finding info on networking from those dubious sites. It's deep @nd isn't going to be cont@ined in @n @rticle on @ h@rdw@re review site.
If you w@nt good sources then look up the IEEE specs @nd RF engineering. It will help lots.
If you'd re@d @ little you'd underst@nd the multiple @ntenn@.
There is no "best" c@rd or "best" @P. Just like there is no "best" router or switch.
You c@nnot t@ke PC @ppro@ches to networking. especi@lly wireless.
