NVRefreshTool is a utility used to fix the problem in Windows 2000/XP that sets your refresh rate to 60Hz when you play ANY game. This problem occurs whether or not you have a higher refresh rate set in your Display Properties of Windows.
NVRefreshTool is simple and easy to use. Just load up the NVRefreshTool program and it will automatically detect the maximum refresh rate at each resolution that your monitor supports. If you're an advanced user, you can customize each refresh rate at each resolution.
Currently NVRefreshTool supports all Detonator versions.
